What seems to be the problem on my 2005 mazda 3. whenever I try to drive faster than 60kph and and accelerating, there seems to be a vibration that increases when I go faster, but it suddenly stops when I stop pressing the accelerator. What seems to be the problem? A CV Joint?
marchemike
  • 649
  • 18
I doubt this is CV joint/axle related as if that was the case you'd feel the vibration regardless of the throttle position. If the problem only occurs during acceleration I'd lean more towards the possibility of a failing/worn engine mount or pitch stopper/dog bone.
John Hall
  • 136
Check the engine mount or the main pulley (balancing shaft harmonic balancer).
pints
  • 96
