The van cranks but will not start now. Checked for spark and fuel, all is good.
Below is the scan results I got. This scan was taken after several tries and checking the cam and crank sensors.
Make: Kia
Model: Sedona 3.8L
Year: 2006
VIN: KNDMB233366060650
MIL: Off
Diagnostic Trouble Codes
Generic Powertrain
P2106 Lime Home Mode - Force Limited Power
P1295 Limp Home Mode - Power Management
P2422 Evaporative Emission System Vent Valve Stuck Close
P0300 Random/Multiple Cylinder Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P161b Unknown Trouble Code Description
P0018 Crankshaft Position - Camshaft Position Correlation - Bank 2 Sensor A
Freeze Frame for DTC P0300
Fuel System Status Bank One Closed Loop
Fuel System Status Bank Two Not Reported
Calculated Load 27 %
Coolant Temperature 93 F
Short Term Fuel Trim Bank One 17.94 %
Long Term Fuel Trim Bank One 0.00 %
Short Term Fuel Trim Bank Two 18.72 %
Long Term Fuel Trim Bank Two 0.00 %
Intake Manifold Absolute Pressure 20.9 in.hg
Engine RPM 2340 r/min
Vehicle Speed 0 MPH
Ignition Timing Advance for #1 19.0 deg
Intake Air Temperature 82 F
Air Flow Rate From Mass Air Flow Sensor 3.15 lb/min
Absolute Throttle Position 22 %
B1S1 O2 Sensor Output Voltage 0.000 V
B1S2 O2 Sensor Output Voltage 1.275 V
B2S1 O2 Sensor Output Voltage 0.000 V
B2S2 O2 Sensor Output Voltage 1.275 V
Enhanced Powertrain
B3b12 Unknown Trouble Code Description
U20bb Unknown Trouble Code Description
P22e0 Unknown Trouble Code Description
B3f04 Unknown Trouble Code Description
B2099 Unknown Trouble Code Description
Automatic Transmission
SRS-Airbag
B2500 Warning Lamp Fault Short To Battery Or Bulb Short
Weight Control System (WCS)
No response from module
ABS / TCS / ESP
BCM
B1102 Battery Voltage Too Low
B1602 CAN Line Error
B1606 CAN Time-Out ADM
Air Conditioning
Powertail Gate
Power Sliding Door LH
Power Sliding Door RH
TPMS
No diagnostic codes retrieved
Zaid
  • 39,276
  • 50
  • 151
  • 294
Ward Ryon
  • 71
Had Dodge shadow do same thing too many codes . I took it to Corbin KY pickards automotive technician and had broke ground in working harness to computer. The technician fixed it in about 20 minutes no more problems after that.dont no if it's what's wrong but from all your codes I'd say good possibility. Good luck
Check the fuse for ENG and see if its blown. This happened to me and that's what the problem was until now. It keeps blowing and now my radio or nothing works and it cranks but wont start. I also have a 2006 Kia Sedona.
Ashley Ann
I'm with /u/Hari Ganti.
It's too many codes to happen all at once, which points to an electrical issue.
I'd make sure you have clean power. Make sure all the grounds are clean and secure. Make sure nothing is shorted etc. I'd check the harness to the PCM. Sounds like a possible rodent issue.
NitrusInc
  • 763
  • 34
