I see conversations like the following a lot:
A: My car won't start.
B: Does it crank?
A: Yes but it won't turn over.
B: Wait, I'm confused. So, it tries?
A: Well it makes a sound.
B: Like whir whir whir or just the clicks?
A: Yes.
B: AHHHHHHH!
What terms and phrases are generally used in the context of observations made of a car starting (or attempting to) and what's the difference between them? I can think of:
  • The clicking sound (not sure what that's called).
  • Crank
  • Turn over (I think that means the same thing as crank? Or is it referring to the moment it moves beyond the attempts and actually starts? Car won't crank, turn over, or start is a good example of a question title where confusion may be present.)
  • Start
  • Maybe other things (like here somebody used the word "catch").
There seems to be a further bit of confusion regarding how far it gets when trying to start, which I can't really describe accurately since I don't know the words, but the progression seems to be:
  • No clicks at all.
  • Clicks only.
  • That "sad" sounding attempt e.g. with a dying battery (and there's also the "really sad" version of this where it just sort of buzzes a little or tries exactly once).
  • A "full strength" failed attempt e.g. a broken fuel pump.
  • An actual full start then an immediate ramp down and stall e.g. an ECU problem or something.
  • A full, happy start.
Is there terminology that can clearly distinguish between those?
Jason C
  • 4,910
  • 36
  • 73
I'd say the following, which seem fairly universal:
  • Nothing - the worst option, you turn the key and nothing happens at all - either the battery is flat, the immobiliser is misbehaving, or the starter solenoid isn't getting any signal/power.
  • Clicking - the starter is engaging, or trying to, but it's not turning the engine. It might be that it's failing to engage, or there isn't any power getting to the starter itself.
  • Clicking and whining - the starter is engaging, but can't turn the engine. Either not enough power to turn it over of (worst!) the engine has siezed...
  • Whirring (with or without clicking) - the starter it turning, but isn't engaged - most likely the solenoid has failed
  • Slow Cranking - the starter is trying to turn the engine, but not fast enough to fire - usually down to a poor battery
  • Fast Cranking - the engine is turning over quickly, but won't fire. It will be missing Spark, Fuel or compression on one or more cylinders...
  • Very Fast Cranking - another really bad one, this means there is a serious lack of compression!
  • Trying to fire / Coughing - the engine turns over fine, and 'coughs' as it tries to fire, but won't keep going - Usually either a problem with ECU/spark, or not enough fuel getting through
  • Starting, but quickly cutting out - usually the same causes as coughing
  • Running - Happy engine!
Nick C
  • 28,941
  • 56
  • 109
I don't think this question has a solid answer, but if we're looking to solidify definitions on this site, then I'll propose this (and it's what I use as well):
Crank = starter motor turning the engine
Turn Over = motor actually starts up
Spivonious
  • 982
  • 25
