I bought a BMW e39 with a bad transmission (ZF 5HP18). I bought another one in a junk yard and I plan to rebuild myself the one that came with the car and keep it as a spare. My question is: after I do the rebuild and put together the old transmission it will be dry without ATF how do I store it (for years)to avoid corrosion on the inside?
Rafael SP
  • 61
welcome on this site.
Good luck with rebuilding the transmission, this is one of the bigger challenges in car maintenance.
You need to store the transmission with ATF inside in a clean dark place with constant temperature. Do not overfill the transmission. Ideally the gearbox is wraped with oil soaked paper/rags
Martin
  • 8,644
  • 27
  • 41
