I did something really silly last night :( - I have a 03 Accord V6 sedan that I recently changed the transmission. After I hooked up the new tranny etc.. I noticed when I start the car the SRS, (!) and the ABS lights came on.
I decided to research it and was following a tutorial online where a lot of people tried and it worked: It basically instructs you to bridge pin 4 and 9 on the ODB2 connector, I did just that and saw a little spark - I immediately removed the bridge and tried to start the car to no avail, it cranks well - just wont start up. I hope this is just a blown fuse/relay somewhere. Any help on fuze/relay location to check etc would be highly appreciated.
**Side note to that, now when I put the key in the Ignition the Green key light keeps blinking as if the immobilizer isnt recognizing the key.
By looking at this diagram, Can anyone tell me what shorting out pin 14 and 5 damage? please
Could I coincidentally have a bad key ? fuse? :(
Thanks for the help in advance.
andre3wap
  • 253
Check circuit F28 for open. (Pin 9 DLC to A16 PCM)
Power Management Diagram
EDIT:
Check pin 3 (Immobilizer) to 14 DLC for continuity.
If okay, may be inclined to replace immobilizer as first course of action.
After replacement, consider researching Honda 'automatic key registration'. Unfortunately, I don't have the time to look into it. Recently, I replaced an immobilizer on a Corolla and the automatic key registration procedure was key to 'on' to 'off' position - 5 times.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Joey P
  • 111
After days of researching and getting help from the awesome folks here and other forums, I have finally came to a conclusion, which yeilds success.
The Story: I bought the 2003 Honda Accord V6 from a guy with a transmission issue, (Could not go in reverse) - days after I noticed that the key wasn't unlocking the door when I pressed the buttons, but it would start the car.
I then changed the transmission successfully and noticed that the SRS, ABS and (!) light came on. I wanted to reset them so I was looking at a tutorial that instructed me to bridge pin 4 and 9... I wasn't paying attention and bridged pin 16 and 5 on the DLC, which blew Fuse #8 under the hood:/
The Succes
I finally decided to stop wasting time and I took it to my dealership for a $120 diagnostic... the service tech that I dealt with hinted that it might be the key because he tried to program the buttons to the car and that didn't work. (I was doubting him the whole time due to what I did) :(
Long story short, I left the car and they did a new key and the car is now running fine!!!!!!!!!
Thank to everyone that put a foot forward in order to help me with this, especially Joey P.
I sure learned my lesson. (No more bridging haha)
PS** With military discount the dealership only charged me 120 for the key and reprogramming.
andre3wap
  • 253
