10
I'm looking at buying some anti-seize compound in a little more bulk than a 1oz tube. The ones I've been looking at come with a brush. A brush as well as coming in 8oz sizes means less waste (direct application), easier to apply, and a lot less messy. One of the things I've ran into while looking, though, is they come as different compounds.
There is (from one manufacturer):
  • aluminum plate
  • non-metallic marine grade
  • nickel-graf
  • moly plate
  • copper plate
  • nickel plate
What are each of these used for and how do they differ? Are there other bases besides what I have listed? If so, what are they used for?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
While I have no indication about the specific products I will try to explain different types of anti-seize compounds.
  • Molybdenum-sulfide forms a great grease, but it is not suited for high temperature applications with nickel-based alloys (AFAIK nickel is contained in most stainless steels and high strength steels): The compound breaks down in molybdenum and sulfide, sulfide attacks the metal, inducing stress corrosion cracking and cold welding. Suited for up to 300°C.
  • Teflon based anti seize breaks down on high temperatures forming corrosive fluoride compounds. Offers also a good lubrication, depending on the product it could be food compatible. Great chemical resistance.
  • Copper based anti seize is to be avoided in combination with aluminum parts. Copper induces galvanic corrosion on the aluminum. Suited for up to 1100°C. Since copper is a toxic metal you should avoid skin contact.
  • Nickel based anti seize is toxic. Finely powdered nickel is not something you want on your skin. Nickel causes severe allergies and other problems. Offers protection for up to 1400°C.
  • Aluminum based anti seize should be compatible with aluminum applications. Good for up to 1100°C. Drawback: There is again that problem with that finely powdered metal everywhere (your tools, workplace, skin etc.).
  • Ceramic based anti seize (My favorite). Since it is metal-free galvanic corrosion is no problem, it offers highest temperature resistance and should be virtually chemically inert. Depending on the product it could be even food compatible.
TLDR: For automotive applications I would choose the ceramic anti seize.
Bob Cross
  • 24,537
  • 85
  • 166
Martin
  • 8,644
  • 27
  • 41
-1
The industry ( repair manuals etc.) advise to use nonpetroleum base lubricants for break hardware. The main thing to remember; any metal to metal parts need an anti seize lube,or moly(synthetic). Rubber to metal parts,such as caliper pins which engage rubber boots & seals need silicone past such as caliper grease.Check out mechanics,who repair vehicles for a living,also,such as Eric the car guy,South Main auto etc. found on youtube.
