I recently bought a 2006 Ford E-350 which I am converting into a tiny home for full-time dwelling. My problem is once that I have about 2 inches of vertical clearance from the ceiling.
My options are:
  • Rip out the existing floor, build a 1 inch frame, lay insulation, then put a new floor in. This sucks because my current floor is a really nice custom solid wood floor left in by the news crew. It's also glued in with LOTS of glue, and it will be hell taking it out.
  • Leave the existing floor in and just build on top of it. This will leave me barely be able to stand up straight in my home. Deal-breaker.
  • Put the insulation in the undercarriage.
Here's what I'm thinking. First of all, I'll stay well clear of the exhaust pipe, which gets super hot. I'll paint the entire undercarriage with a protective coat. Then, I'll bolt sheet metal to the bottom beams. Then, I'll spray expanding waterproof insulation spray into the gap between the sheet metal and the bottom. I won't be able to insulate where the gas tank is (it's too close to the bottom) or the exhaust. In addition to insulating from convective heat loss, I'm also considering using a layer of reflectix in there somewhere to reflect radiant heat from hot pavement.
Is this a terrible idea? What could go wrong? If it's doable, what materials would you use?
crypdick
  • 173
I'm tall and can't quite stand up straight in my transit, or at least not with my feet together. It's not as bad as you think, even when cooking. Even to get this much height I had to be mean with the insulation. Mostly I think about insulation against the cold as I use the van in the UK/France and it doesn't have a/c. There isn't much difference when it comes to insulating against heat.
That said, I've looked into this myself and there are a few things to take care of:
  • The insulation needs to not absorb water thrown up from the road. Expanding foam isn't generally completely closed-cell, and relies on a thick layer to block water. So you need good seals, and/or really good foam (like the stuff used in flotation compartments in canoes; it's more expensive).
  • On the other hand, any water that does get in there will stay there -- this could even be from spillages inside/washing the floor if you have cable holes through the floor. Then it will cause rust.
  • Expanding foam sticks to everything and makes rework hard.
  • Thermal expansion is significant and can open up unexpected gaps. Conversely if you install stuff when it's hot, differential contraction can cause buckling in the cold. Both of these are much worse on the outside.
If I could get the compartments perfectly sealed (and there would be a lot of little compartments in my case) I'd use glass fibre (rockwool) held in by sheet aluminium. It's heat proof enough to use near the exhaust.
I don't see a need to reflect more heat than the sheet aluminium would -- when parked the surface under the van will be mostly in the shade, and the insulation will stop a lot of the heat coming up anyway..
Even a thin layer of something insulating over the fuel tank would help -- perhaps you could buy a sheet of 10mm (~1/2") closed-cell foam mat. OVer the exhaust, either find some heat-proof insulation or do something like floor -- insulation (thin) -- aluminium sheet -- air gap -- aluminium sheet -- heat shield -- exhaust. Both of these are about avoiding big cold spots in the floor, though the fuel tank itself will help to some extent, and the tiny air gap above it
Some thermal bridges are inevitable with van construction, and you will get cold spots where the walls meet the floor with this setup. But you may be able to fix that on the inside (e.g. inside cupboards, or with carpet), and besides, a good layer of insulation underneath will help so much it's almost certainly worth it.
Chris H
  • 819
  • 14
I don't think putting part of the insulation outside the bodyshell is going to be very effective. Metal is pretty good at conducting heat/cold, so your floor will tend to have the same temperature as the outside walls and roof: When it's cold outside, the interior heat will be transported from the floor to the walls, cooling down the interior.
You have to insulate either the entire inside surface, or the entire outside surface.
Most of the floor space in the van will not be places you can stand up in: cupboards, bed, seats. You could put insulation on top of the floor in those places, and rely on a nice thick rug for the places where you can walk. In one campervan I've used a few times, the seating area floor is raised slightly (~+8 cm) above the rest of the floor.
Hobbes
  • 4,422
  • 18
  • 23
An old thread, but still, ...in houses it is accepted as BEST practice to insulate OUTSIDE the existing brick walls, rather than inside
If you insulate inside you will inevitably get cold spots, and that's where the moisture will condense, causing damp, mould, etc. etc. all in hidden little corners where it's difficult to see and difficult to deal with.
If you put your insulation on the outside then then condensation isn't a problem because you raise the temperature of the inside of the walls above the dew point.
In a vehicle, the same applies: insultate inside and you have to be VERY careful to stop ANY air contacting the metalwork, especially in hidden places like under the flooring, because you'll get massive amounts of condensation which will form liquid water in places where it is very difficult to dry out. Closed cell spray foam allows provides insulation with total exclusion of air from the metal shell. It's not cheap, it's potentially messy, and it's not a DIY job, but it works.
Now in theory, you could use closed cell spray insulation on the outside of a van, and that would work very well, but it would look very strange. Under the floor and on the roof it could be applied without necessarily looking too bad.
The space under a vehicle is often in fact a rather calm and peaceful place. Usually quite dry and always with a very stable temperature. You can keep your beer under there on a hot day and it will stay pretty cool.
The problem under the van is that there are all kinds of pipes and components and so on which you need to keep clearances around. It's still worth insulating the areas you CAN insulate though - it never hurts. Closed cell foam wil protect metalwork just like vehicle underseal I reckon, and you've already got the underseal on there so I really don't anticipate any issues with moisture or corrosion. And if you later find you need more space to service components, the foam can always be cut away. I wouldn't enclose it in metal sheeting or anything like that; I would treat it as thick foam underseal.
But to save headroom, why not use closed cell spray foam on top of the roof? That will GREATLY reduce the risk of water droplets falling onto you on a cold night from the ceiling, and will make a massive difference on a hot sunny day.
Applied by professionals it usually ends up as a fairly even and smooth layer. It's really quite tough, and you can paint it body-coloured to protect it from the elements. UV will be more of a problem than rainwater I reckon, but paint will deal with that issue. Just make sure that water can always run off OK.
The problem with insulation foam becoming waterlogged (in boats and so on) generally only occurs in confined spaces where a cold surface promotes condensation from moist air and the foam then soaks up more and more of that water over time in a plce where there is insufficient ventilation for it to evaporate off again. A van rooftop is very unlikely to ever trap moisture like that, ...unless you want to go down the turf roof route, but I don't recommmend that because of the weight of the soil.
pulgato
