I have a 2000 Chevrolet Malibu 3.1. I changed the head gaskets the intake manifolds and the valve stem seals. Before starting the engine and putting everything 100% back together , I wanted to make sure that nothing would sound before starting. While hand cranking I am getting this tapping noise. From what I can see the valve lifters are hitting the camshaft after the Lobes lift the lifters. From a limited view above, i can clearly see the lifter tapping the camshaft when I'm hand cranking. Is this normal? What's going on if not? The pushrods are installed in their correct locations and rocker arms are properly torqued to 11 foot pounds with an extra 30 degree turn according to my service manual. I've lubricated everything. Pulled the valve lifters cleaned degreased and lubricated as well. here's a short video of me hand cranking the engine. The sound is not present when the pushrods and rocker arms are not on. Mind you there's no oil in the engine. Is this the reason why?
Asked
Active
Viewed 1,110 times
Completely normal. You have hydraulic lifters they take oil pressure to work.They will take up the slack that is causing the noise.
Move More Comments Link To Top
- 18,788
- 5
- 54
- 76
