My Cruze has a squeaky belt, noise goes away as I accelerate. All pulleys are turning. Is belt dressing a temporary fix until I get home?
Usually a belt squeaking is due to one of two things: worn out serpentine belt; tensioner has lost spring tension. Of the two, I'd suggest the belt is probably at fault as the tensioner should last much longer than a little over two years.
You can put belt dressing on the belt, but your better bet is to just replace it. The belt should be okay for a little while, but you'll want to replace it soon. All-in-all, the belt dressing is just a placebo. Usually, once the belt is warmed up, the slipping is either stopped or is dramatically reduced. It doesn't mean you you don't need to change the belt, because it will only be getting worse. If you have to go to the parts store to get dressing, it only makes sense to just get a replacement belt and be done with it. There usually is very minimal risk of the belt jumping off of the pulleys or of it self destructing before you can get it replaced, so have no fear of that.
- 165,084
- 32
- 259
- 508
