Its a 2004 Toyota Sienna van 6 cyl in great condition. Belt is not loose and the fluid is full. When it warms up it's, about great 15 minutes. I'm guessing the pump. However, I do have a seized tie rod, so I was told recently when I got 2 new front tires. Is it safe to drive?
Asked
Active
Viewed 408 times
Safe to drive, probably, but it might be hard on your new tires.
Seized tie rod may mean only that they were unable to adjust the position of the stop nut and/or outer tie rod end on the threaded shaft of the inner tie rod end. This adjustment is necessary to complete a front-end or 4-wheel alignment.
However since you said it was hard to steer, it might be missing lubrication on the inner tie rod end joints, which are ball joints (but not the ball joints that hold up your vehicle's weight). This condition will get worse until significant play is present in your steering, and will need to be addressed soon.
kmarsh
- 2,169
- 12
- 37
