My royal enfield 350 classic just had a service and I just noticed a weird Chemical like foam coming out of it. It has hardened now and settled on it. I have posted the photo below. Any help as to what this might be ? It has come out of the clutch assembly side.enter image description here
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
gklaxman
  • 43
There appears to be some this "foam" on the large bolt head above the area in question. Is the battery located behind that "RE" cover? Is the foam coming from that area? Battery acid would do what you are seeing. Be careful wiping this away in case it is battery acid.
CharlieRB
  • 9,015
  • 20
  • 32
