11
I parked my Dodge Viper after driving for about two hours (in July, ~90°F, AC at full blast). Half an hour later I noticed a huge puddle under the engine, on the passenger side.
I am pretty sure it was water since it was thin, odorless, and cool. I'm guessing it was sweat from running the AC but I have never seen it do this before and the puddle was massive - about a yard squared. Is this normal or could there be a leak?
purpleACR
  • 717
  • 27
The most likely cause is the a/c unit. What may have happened is that debris, pine needles,leaves etc may have plugged the drain allowing an excess amount of water to build up and then it relaesed. Run the a/c unit for awhile say 30 minutes. In a safe area like an empty parking lot make some abrubt turns at slow speeds. If you hear water sloshing under the passenger side dash the drain is clogged. If you look under the hood on the passenger side you may see a rubber "L" shaped hose. You might be able to clean it out with a small piece of wire.
mikes
  • 20,121
  • 27
  • 50
Yes its normal. Saw this bundle of water under the car. Frightened me initially. Its water due to condensation. Its nothing to worry.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
