I just ordered a pair of rather expensive LED headlights for my Jeep (KC Gravity Pro).
These have a polycarb protective "lens" which means that it will eventually fade, turn yellow, get chipped by rocks, etc.
Is there a protective film available that I could put over the headlights and change out every couple years? What about 3M clear bra spray (or whatever it's called)?
This might be a really weird question, but I'm pretty particular about my lights, and after dropping $600 on headlights I would like to keep them performing well and looking good for hopefully the lifetime of the car.
Thanks!
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Sponge Bob
  • 1,567
  • 28
  • 36
UV rays are said to be one of the reason of headlights fading, also if you drive through deserts or dusty areas where sand particles impact on car and headlights can cause fading. One of the solution is to use UV Resistant clear coat on headlights its can be available in the market. One time application can last for months.
For deserts and sandy areas where you drive in speed you can put on glass coating on lights to prevent lights from fading.
Syed.AQ
There's a lot of companies selling headlight film - mostly pre-cut to size for OEM. 3M, WeatherTech, Lamin-X. Some wax companies like Meguiar sell fluids that theoretically leave a UV protective layer behind after they clean the lens.
Blackbeagle
  • 954
