When I press the brake pedal, my car is shakes. However, it is fine when I drive it. Does anyone know what's going on with my car and how should I fix it? If I ask someone to fix it, how much would it cost and how long would it take approximately?
Sounds like your rotors are warped pretty bad on the front honestly. Sounds like you need brakes and rotors, might as well do the whole car. Rotors are easily warped nowdays due to quality, usage, and even by hitting a puddle of water after or during braking because it shifts the rotors temperature so quickly from hot to cold that the steel warps. Hence the shaking when braking.
- 242
- 2
- 8
If the car shakes when you apply the brakes while it is moving, then the problem is likely with the rotors. However since it happens when the car is not moving, then I'd suspect a vacuum leak.
Listen carefully around the brake booster (the large round object more or less in front of the driver in the engine compartment), I suspect that there is a leak that is causing the idle mixture to change, probably too lean as air is being pulled in when the brake is applied. That cause the engine to stumble.
- 14,506
- 8
- 52
- 85
This would be your rotors needing replacement, try braking hard from 50 km/h but not to the extent of hearing the tires squeal or reaching a complete stop, if you feel some vibration in the driving wheel then the rotors are pretty bad, if not, try the same thing from 100 km/h; if you feel vibration, the damage is somehow less but still needs changing. I've changed mine along with the brake pads and now there's no vibration at all.
- 1
- 1
