My car is Toyota Corolla 2011. CEL lights at 75 mph.
I pulled code p02757. There no other thing wrong. The car is running satisfactory, this check lamp is the only trouble.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
abdul
  • 81
A P2757 DTC is a torque converter clutch solenoid valve issue
The valve engages a torque converter at higher speeds to lock your transmission and engine at a 1:1 ratio. This engagement, obviously, only happens at higher speeds for fuel saving.
Causes include;
  • Dirty transmission fluid
  • Faulty line pressure solenoid valve SLU
  • Line pressure solenoid valve SLU harness is open or shorted
  • Line pressure solenoid valve SLU circuit poor electrical connection
  • Torque converter clutch
  • Valve body is blocked
Link to Additional Information
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
