18
I live in a very hot climate where temperatures regularly touch 45 deg C and the heat in the engine bay area means that under-hood wires, especially the thinner ones, endure high levels of thermal fatigue.
As a result, when working on older cars (10+ years) I am very apprehensive about flexing any wiring in the engine bay area in case I introduce a break (and a new headache). This includes wires for things like coolant temp sensor, MAF sensor, coil and injector power supply
Is there anything that one can do to delay the onset of wire embrittlement? Would it help if manufacturers use a different grade/gauge of wire to help with longevity?
dlu
  • 14,506
  • 52
  • 85
Zaid
  • 39,276
  • 50
  • 151
  • 294
Heat and thermal stress, even at engine bay temperatures, is not generally the cause of copper wire failure. There is "hydrogen embrittlement" for copper but that only really comes into play at 400C+ in hydrogen-rich environments, usually during annealing. Also, the 20-30C higher range from your hotter climate is pretty negligible from copper's point of view.
Copper's linear thermal expansion coefficient is roughly 17 micrometers / meter / degree C (off the top of my head, you can look it up though). It's very negligible in the lengths found in most wiring applications and especially negligible when the wire is just hanging there with plenty of space to expand/contract without inducing mechanical stress.
Copper is also specifically chosen for wiring because of its high tensile strength and great durability, not just its high electrical conductivity. Aluminum, for example, is a lot cheaper, makes perfectly fine wiring, but has a lower tensile strength and higher thermal expansion coefficient, meaning extra care needs to be taken to managing it (aluminum's big advantage is cost and weight; they use it in a lot of long distance overhead wires).
Copper also has a high thermal conductivity, meaning "hot spots" in wires tend to even out quickly, reducing internal stresses due to uneven expansion. It also has a fairly high resistance to corrosion from environmental factors like moisture and oxygen, although of course it is not immune and this can be an issue over time.
In a way, copper is the solution to the types of stresses that wiring generally undergoes in an environment like an engine bay.
The primary failure modes of wiring are usually:
  • Insulation failure: Cracking insulation leading to shorts that can get hot enough to melt copper. Insulation failures can be caused by heat, UV, environmental factors and degradation, etc.
  • Galvanic corrosion at connection points: Aluminum, steel and zinc will generally corrode when in electrical contact with copper. Copper will generally corrode when in contact with stainless steel or brass. This can weaken connections over time.
  • Oxidation: While copper is pretty resistant to oxidation, it still happens over time (e.g. the Statue of Liberty is green, and you can certainly spot lots of corrosion in exposed copper wires in aging vehicles) (actually copper oxides aren't green but ultimately they turn into green copper carbonates/sulfates like malachite and such). The corroded copper is much more brittle than the metal. Obviously, wiring with more surface area, such as stranded wiring, will have a bigger issue. Also if the insulation is cracked or permeable to oxygen, that's another potential source.
  • Edit - I guess mechanical fatigue is worth mentioning too, perhaps due to past abuse during maintenance or fatigue due to vibrations in really unfortunately placed wiring. Copper's pretty resilient to this but certainly not immune.
Oxidation is probably the issue that'll cause you the most problems over time.
So from all that I would say:
  1. Manufacturers are already doing the right thing just by using copper to begin with.
  2. You might be able to slow it down by e.g. spraying good insulation onto exposed points but... there may not be much to improve.
  3. In a vehicle that already has heavily corroded wiring there's nothing you can do to reverse it.
  4. Get used to old wiring breaking as a fact of life and budget time for wiring replacements after a visual inspection of the state it's in.
  5. Using thicker wire wouldn't hurt but may not help. More importantly, use wiring with good, flexible insulation rated for outdoor environments and engine bay temperatures. Silicone is a good choice.
Jason C
  • 4,910
  • 36
  • 73
10
When you say "embrittlement", are you talking about this?
This is a common issue with PVC used as insulation: PVC is brittle by nature an needs plasticizers to be added to it when making cable insulation. Over time, plasticizers evaporate (remember that "new car smell" which gradually goes away?), brittling the PVC.
You could keep your car in the garage and not under sunlight / rain. That will reduce both copper corrosion and insulation embrittlement.
Obviously, using bigger copper gauge and thicker insulation would make wires more robust. Also, replacing PVC insulation with a more robust one (XLPE or similar) would also help. Since it would also be more expensive at no benefit to the manufacturers, they wouldn't bother.
Dmitry Grigoryev
  • 2,662
  • 14
  • 29
The very short answer is that heat isn't a significant problem for the wire. Heat is a problem for the insulation.
So if you have wires failing I think there is something else going on.
The problem with dealing with failing insulation is that there isn't much you can do about it – short of rewiring the affected parts. In a modern car that could be a non-trivial project. As Agent_L mentioned there are good high temperature insulation materials, but retrofitting them isn't really practical in many cases.
There are a few practical things you can do:
  1. Heat shrink tubing, though this usually requires reterminating the wire since most heat shrink won't shrink enough to fit over most connectors.
  2. Electrical tape, it's not elegant, but it can be effective and is relatively easy to do.
  3. "Paint on" electrical tape – I've never used the stuff, but it is available and it might work well in some applications, I think it would do a better job of excluding moisture than tape.
  4. If the affected area is small and the car is old one of the easier approaches might be to replace the section of the wiring harness, or to rebuild it. If the car is old then I wouldn't even worry too much about getting better wire, unless it is a classic, as the replacement wire will last for many years before it fails.
dlu
  • 14,506
  • 52
  • 85
If you can't find silicone insulated wire, try nylon coated pvc insulation. it's very common at any electrical supply place. It's rated for higher temperatures and the nylon coating helps protect the pvc from degrading. A little more expensive than regular wire, but less expensive than silicone insulated wire.
BenThere
