I have a 1996 Lincoln Town Car 4.6 liter v8 engine. I have replaced the water pump due to it leaking and car running hot. It still ran hot, so i replaced the radiator, thermostat, and the cap that goes to the coolant. My car is still running hot and I am not getting any pressure in the area that I put the coolant in. Usually I can't take the cap off due to it being so hot and it might go into my face but instead its not. Please help if ya can thanks.
Temp reads hot on the digital screen and the coolant tank is full.
Moab
  • 8,035
  • 32
charlie
  • 31
Did you test the new thermostat in a clear glass with hot water from a kettle? did you actually see it open when you poured hot water into the glass? you could have tested the old one first, how do you know you have the right thermostat for the engine? Are the cooling fans/fan working when the engine gets to hot?
