My issue is similar to this question over here (intermittent crank no start). Though my no-start is now definite and no longer intermittent.
I have had no starts about 60% of the time when I try and start my Honda Civic 97 up, especially on cold mornings, but even when the car's warm. The main-relay clicks, but no crank. Then I'd use an old butter-knife that I kept in the car to link the negative and positive on the starter and make the starter crank over; if the car's warm, it would startup, otherwise I'd swing the key again and pump the accelerator and it would startup.
Last night however, I started the car up with the key (no butter knife) and the main-relay clicked like crazy (like 20 clicks in that couple seconds), but the car started up. Then when I left McDonalds it clicked like crazy again, but no start. Then when I tried the butterknife on it, it sparked like crazy and the butterknife got hot (I was holding a cloth around it, so I didn't burn).
Note: the starter and alternator were overhauled just over a year ago Had to kick start it to get home. What do you guys think my problem is? Gonna go to the auto-electrician this afternoon, but I don't want to pay a ton for something I don't need and also for next time, or if I can fix it myself, I wan to know.
Edit: Okay, this video explains my issue exactly.
pythonian29033
  • 335
  • 19
First of all, connecting negative and positive connections with a butter knife is called a short circuit. I am surprised that you didn't burn a fuse, start a fire or explode the battery yet. DO NOT SHORT CIRCUIT TERMINALS WITH BUTTER KNIFE! IT IS DANGEROUS (and I don't actually understand why you think it would help?)
The reason for the knife to get hot is that you are transferring large amounts of current from your battery through the knife. It will destroy your battery and may even cause it to explode. Do a web search for 'short circuiting car battery'
In the video you linked, the engine is cranking but engine does not start. So I think it is not related to your
It sounds like your starter or connections to your starter is broken. Perhaps when you touch the starter connections, you inadvertently caused them to move and reconnect properly.
Your question may be duplicate of: Honda Civic Clicks but won't Crank
Evren Yurtesen
  • 1,208
You didn't mention a new battery, they last around 3-5 years.
Check the battery cable connections for oxidation and coke buildup. Either of those will limit the amount of power going to the starter.
Get a terminal brush and a few wrenches and you can clean then yourself.
If the copper cables look green and brittle you need new cables.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Phlink
