13
From the obsessive compulsive department:
I've been changing my own oil by driving up on a pair of ramps, draining and filling. Based on a slight overfill condition after adding the specified amount of oil and returning the vehicle to level, I know I'm not getting all the old oil out. This makes sense, since the drain plug is towards the front of the oil pan. Oil must be pooling at the back of the pan due to the angle from the ramps. It can't be more than a couple or three ounces.
I'm not worried about the slight excess. Shaving a couple ounces off the amount added next time will put it spot on. I don't like the idea of leaving a measurable amount of dirty oil if I can avoid it, especially on the one vehicle that only gets out of the garage a few months a year.
I suppose I can try and get another pair of ramps under the rear wheels if they'll fit. Jacking up the rear to level the vehicle would work, too, I guess. Any other ideas? Am am I the only nut that worries about a couple ounces of dirty oil?
Mark Johnson
  • 3,931
  • 33
  • 56
8 Answers8
10
For OCD you can place a flat pan below the oil drain and lower the front wheels to get the remaining oil out, then jack it up again.
Though I would not worry about couple of ounces in your place. Even if your car is level old oil will still remain in the engine (other cavities, thin film, etc.).
For example in my engine that takes 4L of fresh oil, 2 ounces is less than 1.5% of it.
In case you need to flush the old oil completely (e.g. after filling with wrong type of oil) you could use a oil flush mixture (drain old, refill with flusher, idle 5-10 min, drain, fill new oil).
Kromster
  • 1,026
  • 22
Use a pump to remove the oil, and skip the ramps -- unless needed for the filter. I can not imagine it makes any difference-- some oil is left no matter how well you drain. Use better oil or change more often are other answers. The oil gets dirty immediately anyway so I wouldn't want to do anything that could be unsafe like raising all 4 wheels -- just buy a good jack and stands and lower the car to the ground or go with the pump if it bothers you. I'd forget the "problem".
Joel H
  • 41
You don't need to worry about draining every last drop of oil. Just make sure that you change the oil and filter regularly every 50,000 miles as I do. My 4 cars perform as new with an average of 165,000 miles, 2 diesel and 2 gasoline.
lewis
You can get more oil out of the bottom if you take pan off once it's empty. The difficulty of doing this will vary by car, of course. Just be careful if the oil is hot. And you will probably need a new gasket for when you put it back on.
staticsan
  • 319
don't to nothing with your car let it stand on a leveled place then open the bolt and drain it out or you can rise it up a little bit up form the behind and drain it out this will work.
Nick C
  • 28,941
  • 56
  • 109
Back the car up on the ramps so the rear wheels are up, if that allows the plug and filter to be accessible. Be sure to put good (not plastic) hocks on the front and test the integrity before you go under. Remember the weight is in the front and if your not on a completely level pavement it will roll off the ramps and then your bug food. Krona solution btw is the right one, but not really answers the question.
rhill45
  • 257
Oil should drain better on ramps in my opinion due to the angle. Think about a square shape container and the drain hole at the bottom. Usally vehicle drain plugs stay at the side note exactly at the bottom of the oil pan. I'm pretty sure on ramps oil would drain properly.
-2
This has probably gone around the table a few times by now, but thought I'd add my method, for any who may be interested. When I change my oil (2012 Ram 1500 5.7H), I raise truck for access to plug and filter only, do the draining, replace plug, drop truck down, add 1 quart of fresh CHEAP 5W20 ($3.00), run two minutes (just to flush old film, and what is caught in the nooks etc.) Re-drain, replace plug, change oil filter, drop truck, fill to proper level ALWAYS. There is a reason for the oil level lines, they run BEST when filled to prescribed level. Doing it this way, I get a CHEAP FLUSH every time I change the oil, AND I get MOST of yesterday out of the crankcase (I don't think we'll EVER get out ALL old residue). I use Mobile One FULL synthetic (5W20) and FRAM Oil Filter, (Ultra Synthetic XG2 24,000km). Hope this tidbit helps someone out. :) Sgb/unidrv
unidrv
