I am working on my honda ridgeline 2006 vtec 3.5 v6 and need help. I marked the pulleys but did not mark the old belt the camsaft in the back spinned on me twice the first time put the cam back to tdc ccw put the belt on again saw that the front cam went back 1 space and the back cam 2 spaces back wards so took off the belt off again and tried to put cam forward 2 spaces but this time it spinned again is the timing on this off now or is everything ok and just put the timing marks at there tdc mark and everything is ok to reinstall the timing belt . changing the whole kit except for the seals Thanks Dan
Asked
Active
Viewed 1,863 times
As long as the marks on the camshafts and crank line up it's fine. Make sure you have enough slack on the tension side of the belt to prevent spinning. It also helps to install the tensioner after you have the belt in place.
Also make sure to spin the crankshaft two revolutions by hand and recheck your marks.
Ben
- 10,686
- 4
- 23
- 54
