How do you top off / fill the differential on a 1996 Chevy Caprice? Can it be done without taking the cover off and changing the gasket? Any gotchas to watch out for?
Mark Johnson
  • 3,931
  • 33
  • 56
There are two methods I use.One is to attach a piece of hose to the pointed tip of the gear oil container and stick the other end in the differential.Then squeeze the bottle.The other method is to use a suction gun that looks like a big metal hypodermic syringe.You suck the oil in then push in the plunger and squirt the oil into the fill hole.
mikes
  • 20,121
  • 27
  • 50
