19
So today was that epic event of walking out into the parking lot at high noon, sun blazing, and finding out you have a completely flat tire. Skipping over the usual details about changing out a tire with insufficient equipment on scorching hot pavement, I changed out the tire for the spare and dropped the flat tire off at a tire shop for repair.
When I got my vehicle home and was putting away the spare, I noticed that the nail was still in the tire itself. The nail appeared to be a roofing nail based upon the size of the head. There also appeared to be some sort of sealant surrounding the nail.
My question is if it's normal to leave the nail in the tire or not. With previous leaks, other repair shops have removed the nail or screw. I haven't been to this tire shop before so I don't know if what they did was standard practice or not.
6 Answers6
47
Nope, not normal
You do not leave a foreign object in a tire under any circumstances. The object can dislodge itself during higher speeds and lead to deflation creating a very high risk event.
If they plugged the tire there will be a rubber plug with vulcanizing glue but not a nail or other related object.
Validate that it's not a rubber plug, if it's not, go back to the shop. This is not normal in my experience and IMO very dangerous.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
No, that is not normal. It needs to be removed and the hole should be patched from the inside. Sealants or plugs are not usually a recommended fix.
john D.
  • 552
Is it possible that you got the flat tire by driving over several nails? There may have been multiple nails in the tire and the repair shop only removed/repaired one. The fact that they may have missed one is in itself inexcusable but this could explain the situation.
Many shops repair a nail by not demounting the tire from the rim/wheel. They simply remove the nail and then use a special tool to buff the hole and than another tool to insert a rubber plug. When this process is done it would be easy to think that there was a single nail that caused the flat tire.
cdunn
  • 9,326
  • 44
  • 76
Definitely not normal.
Absolutely agree with DucatiKiller
The only time it is best to leave a nail in is BEFORE the tyre has gone flat and you intend to drive somewhere, immediately, to get it repaired.
If the tyre still holds air, it might just get you there. Pull it out and it will not.
Please come back and tell us all that it is a plug that you can see. If not, that company really, really, should not be trading.
It is a good idea to leave the nail in the tire when you take it for repair as it shows the shop where the damage is, or at least some of it, and what caused it. This helps get a faster and more certain repair on the tire. However, during the repair they should remove the nail - they should never, ever leave the nail in after they have fixed the tire!
If there is still a nail in the tire either they didn't remove the nail during the fix, or they didn't notice another nail in the tire. Either way they didn't do the job right and you should get your money back.
GdD
  • 18,048
  • 38
  • 67
-5
Tires are one of those things that you don't repair. If it's damaged/compromised, just buy a new one. Tires are cheaper than back in the past, and speeds higher.
Quora Feans
  • 131
