My car is overheating while idling at light. I have been driving it without a thermostat for about 6 months. I have had the water pump replaced and the reservoir. I have also replaced the reservoir cap. I have driven it for 3 days with engine/ radiator cleaner in it to make sure there is no clog but the car is still running hot. Any ideas where to go next?
Asked
Active
Viewed 450 times
I'd check to make sure that the fan in front of the radiator is operational and not missing any fins or the shroud. And it would be best to install a thermostat, since your cooling system probably isn't pressurizing without one, which means it can absorb less heat.
Do not check with your hand!
Joe Makes Things
- 156
- 3
