My Toyota Corolla 2014 Altis auto door lock has not been worked.
I read Electric central door lock does not work with automatic transmission shifting to and from “Park” and also Toyota Corolla Owners Manual: Automatic door locking and unlocking systems. I follow the instruction in the user manual, However, I couldn't set this option on my cars anyways.
I found Automatic Door Lock Closing CANBUS OBD system suitable For New Vios Corolla and Toyota Auto Door Lock OBD but I'm not sure that is compatible with my car and it's very hard to buy those OBD.
Edit1:
Note: The central door lock works correctly with remote key and also with driver's door lock switch.
My car's gearbox is AT.
Edit2:
Ok, according to @Ben Answer I research for configuring the Auto Door Lock on the ECU. So after I googled I found these videos:
  1. How To Use Toyota Techstream Part 1.
  2. Toyota Techstream Software Demonstration.
So I understand that I can do this with Global Tech Stream (GTS) software and the cable that named MINI-VCI J2534.
Question: I'd like to modify the ECU settings. Is it a risky work? What's the difference between the original and fake MINI-VCI J2534 (I saw this video too Disassembly of the fake mini VCI cable, however, I didn't understand what's its means)?
Thanks in advanced.
Arani
  • 131
It looks like the only option other than an aftermarket system would be to goto a Toyota dealer or a independent shop with the Toyota TechStream Software and to enable this feature.
It looks like this option should be on by default but was never setup or was disabled for some reason.
Edit:
It looks you may be able to do this from the Multi-Display.
SET UP / Vehicle / Vehicle Customization / Other vehicle settings..
Ben
  • 10,686
  • 23
  • 54
