The clear coat on my car's finish is getting kind of tired, dull and scratchy.
Is there any way to recondition and renew it?
I assume I will need to polish the existing clear coat somehow and then apply additional new clear coat with an air brush or something like that. What is the procedure?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Cooter Davenport
  • 1,201
  • 14
  • 26
Clearcoat that is dull can be polished back to a nice shine in most cases. A polish of the correct grit and type is needed. This one works well for us, others are available.
Polish
A "dual Action" polisher is the easiest tool to use. Polishing can be done by hand with much time and effort. A single action rotary buffer tool can be used but needs an experienced hand to avoid damaging the paint.
Polisher
First clean the whole vehicle to remove all contaminates. High pressure water is used to clear all grit from crevices. Then as an optional step would be to use a clay bar to remove stuck on contaminates. paint contaminates Clay bar kit
Follow the instructions for the chosen polish; usually this involves polishing one small area at a time. Clean off all the dried polish. As long as the paint is intact this is all that will be needed. Applying new clearcoat by itself is not a common repair.
Fred Wilson
  • 11,667
  • 30
  • 49
