I recently obtained an RX7 and was told it worked fine but would not start due to the clutch going out while it was sitting some wires near the alternator were chewed by rats too, so after the wires and the clutch were all fixed I went to try to start it it won't turn over. When I connect the battery to it and turn the key I hear a loud buzzing sound coming from the engine bay, somewhere near the alternator, all the error and warning lights up on the dashboard also light up and a shift up light comes on the dash. If I turn the heater on the buzz goes away, but when I go to turn the key nothing turns over at all.
The engine does turn over freely, I tried by hand.
I will be checking for fuses/power tomorrow, and may be able to read an ecu error code if there are any, but I as wondering if anybody knew what could be causing this problem, thank you for any help!
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Iqbal Khan
  • 696
  • 19
There may be a lead plate weld broken inside the battery. I would try a new battery, or at least determine if the battery is taking a charge before trying anything else. You can measure the OCV "open circuit voltage" of the battery by connecting a voltmeter between the positive and negative terminals of the battery with the the car completely off. And NO chargers of any type connected now or recently.
Anything below 11 volts warrants a new battery. Really, anything below 12 volts is marginal. My guess is yours will read 0-5 volts. Dead. Cannot be resurrected by any means other than replacement.
SteveRacer
  • 12,432
  • 26
  • 47
