I spent all weekend trying to fix why the lawnmower would sometimes not start/stay started. It needed maintenance anyway so I changed the spark plug, changed the oil and even rebuilt all the o-rings on the carberator (it leaked). It still wont start/stay started.
But I found the issue: the safety stop cable (attached to safety handle) has some play on it. If I give the exposed cable a pull while pulling on the pull cord it will always start. And when it starts to die if I tug on the exposed metal of the safety stop cable it will not stop.
I'm just not sure how to adjust it. The mower is a Troy-Bilt 675 ez start mower with a 190cc Briggs and stratton engine. this is someone elses image that looks 99% identical to mine
Marc Young
  • 163
You could try unhooking the cable at the handle and then tie a loose knot in it. This may make the cable too short. In that case you could drill a hole in the safety handle bail a little further up.
I'm fairly certain it's not adjustable at either end. The proper repair requires replacing the cable. Believe it or not, sears.com has an incredible range of replacement parts, even for brands they do not sell.
I always defeated those things permanently. Yes, it may be unsafe so I'm not suggesting you do. But I live in a wooded area, and refuse to have to restart my mower everytime I need to remove sticks from the mowing path,
SteveRacer
  • 12,432
  • 26
  • 47
