I have a 2001 Dodge Durango, and the passenger-side brake light will not work, even after replacing the bulb.
The bulb that I replaced was obviously burned out. I double-checked the new bulb, and it looks fine. I checked the connectors on the inside of the bulb housing, and it looks fine as well--very clean. I thought about a fuse, but figured if it was the fuse, all the brake lights would stop working.
The tail-lights work fine, as do the signals.
Any insight?
Tyson Phalp
  • 221
7 Answers7
I finally got this figured out.
The housing inside the actual tail-light assembly had become deformed, I guess due to heat, thus keeping the light-bulb housing from making proper contact with the tail-light assembly. A new tail-light assembly fixed the issue.
Thanks, everyone, for your help with this issue.
UPDATE: Recently, the same thing happened on the other side of the vehicle. Replacing the entire housing fixed it. I wonder if this is a common issue with this model?
Tyson Phalp
  • 221
Last time I saw that problem it ended up being the socket on the vehicle. Could also potentially be wiring of course.
Brian Knoblauch
  • 12,548
  • 35
  • 41
I would still check all your lighting fuses, sometimes your brake lights/taillights will be on separate fuses.
Wakeeta
  • 146
For me, it was the brake light housing on both sides. MY OPINION...this is a crappy design!
The 3 little points, once you twist on the housing, barely makes proper contact. I had to rig up something to make better contacts.
Left brake light was not working. The brake light would come on when turning on headlights so I knew the bulb was good. Bam! Contact with the housing was the problem. Manually pulled the small contact tabs out to make better connection. Also swapped the right light for the left and they both worked.
user14428
OK. I have used some of your troubleshooting issues to direct my issue. As I found out similar questionable possibilities to resolve my issue I, went to look at my left tail light assembly again. Utilizing some of the resolved scenario's, in exorcising an issue, I resolved the problem and is now fixed as I was pulled over this morning. My concern was a major.electrical problem. Well. Here is what noticed and how I fixed it. I bought the vehicle with the light out. Fixed it with another light assembly purchased at Cagles in Muskogee County,OK. It worked. After about 4 mo. It went out again. Switched the lights and worked again. About 3 weeks later. Pulled over. No ticket, but a concern. I pryed the silver prongs toward the light at all three areas at both lights, used a sharp knife . In addition , I used plyers to pull down the three brass looking prongs. Did this at six areas. I noticed one silver prong to the light assembly was seated a little from a heat issue. Pulled it out of the melted area a little to increase contact per continuity. Long story short. It works. But a noticeable area of heat is there concern. Works for now.
Had the same intermittent issue, usually losing one brake light at a time, swapped the bulb holders and occasionally the problem would fix itself.
However, eventually I could not get either brake lamp to work, even though the third (center) brake light always worked (proves the brake pedal switch and fuse were good).
Turns out, my problem was the bulb holder contacts, I used a flat screw driver to bend the prongs towards the bulb for both holders and this fixed both brake light indicators!!!
Apparently those contacts lightly deformed (bent) over time until they lost contact!!!
Thanks to those on this thread, my fix was free!!!
