I replaced the bulbs in the interior dome lights in my jeep with LED's. In front, there are two lights - driver and passenger. In back, there is one. The old lights were too dim, the new LED's are great - much brighter.
They are supposed to turn on when you open the door and you can also push on the light itself to turn it on / off.
With LED's though, when the lights are supposed to be off they are on, but dim. Its not enough to see in daylight, but just enough to be a little distracting at night. (Basically, if the key is in the ignition, the LED's are always on dimly).
I assume this means that there is always some voltage running thru these even when supposedly off. Why wouldn't they switch off completely? Nothing seems to stop working when any of the bulbs are completely removed.
How can I fix this - so they switch off completely, and without reducing the brightness when turned on?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
joeking
  • 161
Some cars have timers that keep the lights on for so many seconds after you close the door, this is done with an electronic timer and the timer may not be compatible with led's, leaking voltage.
Only solution is to locate the timer and wiring diagram for it and bypass the timer, this would require some skill.
Moab
  • 8,035
  • 32
-1
You need to add a 1000 OEM resistor to each bulb From what I read the LEDs don’t take much wattage to run so they stay on really dim I I bought a packet of the resistors and I’m going to switch them out I tried it with out and they stay on real dim so this is supposed to fix the problem
Ken
