I have a GSXR 600, and the live side of a circuit touched the frame and blew a 30A fuse. I changed the fuse and now I have no power. Does any one now why? Thanks
The thirty amp fuse is your main fuse
To ensure we are speaking using the same nomenclature, K1 is referring to model year 2001 in my verbiage.
This 30 amp fuse supplies all the power to your fuse block with various 5, 10 and 20 amp fuses populated.
I have quite a few hours on this bike and have seen a scenario that you are describing. Here are some recommendations.
Check your 30 amp fuse for continuity with a multimeter. Sometimes they come out of the box bad. Rare but possible
Check your starter circuit fuse under the seat. When you say 'no power' does that mean headlights and everything or no power to turn the starter. Is it a global 'lights out' across the board?
Check all of your lower amperage fuses. Some of them might have been taking out when the incident occurred.
- 32,976
- 22
- 150
- 267
