I want to update my ECU mapping on my motorcycle to the latest one supplied by the manufacturer, but I'd also like to see what changed before doing so. I downloaded what was on the bike ECU and also got the latest release from the TuneECU website. I opened both with TuneECU individually and also in compare mode, but I can't see any difference, yet they have different versions in the meta-information and different file sizes. I'm not experienced with the TuneECU software, so it's also possible I'm using it wrong.
The F1 Table in both of them looks like this: enter image description here
Can anyone please explain how to read a map and which of the tables are used when? And is there any difference between the two maps?
  • On board - map version 20630
  • Latest - map version 20654
Vehicle: Triumph Tiger 800, standard exhaust, no ABS
Latest Triumph Maps.
I also put both the maps I'm trying to compare in Dropbox: https://www.dropbox.com/s/r0pmhwz4c0a6vhe/Tiger-OnBoard-Map-20630Map.hex?dl=0 https://www.dropbox.com/s/yg9yr6pyiz9p7ja/20654Map.hex?dl=0
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Alin P.
  • 1,334
  • 20
It's very possible that there's no difference to the calibration itself. It depends on the manufacturer, but you'll commonly see revisions that are simply an operating system or process change, where the logic that interprets the tables gets tweaked, but the actual calibration data remains the same. If you look at the actual MAP file in hexadecimal, and the area your tables are stored in didn't change, but there's a whole bunch of stuff at the start of the file that's different, that's probably what's happening.
As far as how to read the map and which one is used when, that will also vary depending on what it is. Ford ECU's have something like 16 sets of tables they'll blend across. In general, whether the engine is
  • MAF or Speed Density based (does it use a MAF sensor for airflow, or does it use a Volumetric Efficiency/ VE table to measure airflow)
  • Running in Open Loop vs Closed Loop (is it using feedback from the oxygen sensors)
..Alters which tables you want to look at, because they determine whether the ECU is just going to run based off of a sensor (more or less), or if they're going to use your table directly. Some tables like ignition timing are obviously critical and are used all of the time.
Drewster
  • 286
