Can anyone suggest a tried and tested method for refinishing suspension springs. The springs I have at the moment have shed their protective coating which I assume was some sort of powder coating?
I'm looking for a finish I can apply that will be durable enough but also flexible enough as I know the springs constantly expand and contract whilst driving.
I'd considered straight auto body paint, a plasticoat style plastic based paint, threading "heat shrink" over the length of the spring and heating it to the required temperature.
I wondered if anyone had actually refinished their springs and what level of finish and longevity they've had.
Steve Matthews
  • 23,464
  • 41
  • 92
The very best solution is to powder-coat them - but you need to get them to a paint-ready condition before you take them to the powder-coating company; otherwise, it could cost quite a bit. Harbor Freight sell powder-coating kits, but I've never tried them, and if this is a one-off job, sending it to a company will be the most cost-effective solution.
Another alternative is caliper paint. You won't need to work as hard to clean the springs as you would for powder-coating, but the better the surface preparation, the better the finish.
PeteCon
  • 8,722
  • 17
  • 30
Aerospace landing gear applications usually require springs to be coated in Duralon (name brand), which is a Nylon compound that is applied much like a powder coat. It is used for its flexibility, impact and corrosion resistance, and it provides a smooth, clean finish so damage and defects are easier to visibly identify.
MooseLucifer
  • 6,027
  • 28
  • 55
