As user Steve Matthews pointed out on my last question Car interior rattles on idle The ideal use of a coke is "Use the choke until the car warms up properly. You can reduce the amount of choke gradually until it's fully off and keep the car running smooth."
But this brings up further questions that after an hour of searching I found no info on.
  • What is the optimal use of a choke?
  • What are the cons of using it incorrecly?
  • What consecuences does wrong use of choke have on the long run?
  • How important is it to gradually ease off the choke as the car starts warming up?
  • How important is it to not push the engine too far while choke is engaged?
For reference the car is a 1985 Citroen BX, the choke is manual (maybe autochokes weren't popular in Spain) and the engine is a carb. Sorry I don't have a pic at hand but I'll definetly add one once I'm home!
EChan42
  • 1,005
  • 23
You should avoid over-use of the choke if possible, as over-fuelling the engine will cause more carbon build up, shortening the life of the plugs and reducing the time before the engine needs a "decoke" to get rid of the build-up. Plus it wastes fuel! Of course, too little is just as bad...
I've always gone for the following, though I don't know if it's optimal:
  • Pull the choke out fully
  • Start the engine
  • Immediately push the choke in until the engine just starts to struggle, then pull it back out a little bit so the engine is happy.
  • Start driving.
  • Gradually push it in, a bit at a time, over the next few minutes - the time needed will depend on the ambient temperature, and how quickly your engine warms up. From a warn start you might be able to push it fully in straight away.
You should be running with just enough choke that the engine is running smoothly.
Don't push the engine too far until it's fully warmed up, regardless of whether you're using the choke or not. If you do a lot of short journeys, make sure to regularly take it for a long journey to get it properly warmed up.
Nick C
  • 28,941
  • 56
  • 109
Knowing how to use it as explained by Nic C
Fouling spark plugs which will cause a misfire even after it warms up.
Gasoline getting in the oil past the piston rings due to being over rich too long and and causing pre-mature engine wear and lower compression due to the rings being washed out from raw unburnt gas.
What consequences does wrong use of choke have on the long run?
Same as last question
Very important
Regardless of the choke it is hard on an engine to put too much load on it when it is cold. When oil is cold it does not flow well and this can cause pre-mature engine wear if you do not let the engine warm up all they way before romping on the gas pedal or pulling a heavy load (trailer).
Moab
  • 8,035
  • 32
