In my 1986 Ford F-150 (carbureted) when I go left around a corner, the engine sputters. Feels very similar to running out of gas, but it picks back up once I stop turning. Only happens in a sharp corner, and only left, not right.
I've experienced this before in a 1995 VW Golf. In that case the engine only cut out when turning right. I had it serviced at a shop back then, and as I recall it was something in or near the gas tank along the fuel line that had cracked and was letting air into the line.
Is this a common problem? Any highly suspect parts I should be checking?
Troy
  • 390
My theory is you have a stuck float in your carburetor. This is causing the fuel bowl not to fill completely. When you go around the corner, the main jets are without fuel (sucking air) and this kills engine power. Getting the carb rebuilt (or at least looked at) will probably solve the issue. You may also try using a plastic handled screwdriver and using the handle, thump on the fuel bowls a few times (don't do this too hard). This may release the float and allow it to run right temporarily. Usually, this isn't going to cure itself.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Kind of a long shot, but I had this problem with an old Nova, turning right. That was due to loose screws in the carb. It might have been the mounts to the intake manifold; but, my vague memory is of tightening screws on the topside. It was a long time ago.
George
  • 1,133
  • 18
