10
I have a 2007 Nissan 350Z and there is a trim bar inside of my car that feels electrified. I even touched my tongue to it (please, I know) and I can feel electricity. It's similar to if you have ever taken a 9volt battery and touched it to your tongue (older brothers).
Here are some parameters. If the ignition is off and the doors are open with I can feel it. If the ignition is off and the doors are closed, I don't feel it. If the ignition is on I feel it with doors open or closed.
The trim piece is fake chromed. I thought plastic underneath the fake chrome look but I'm not sure.
Everyone I've asked just stares at me and shakes their head. They usually follow it up with something like, 'that's weird'.
I've had my battery ground checked and made sure there's no buildup on the batter terminals.
Any tests I can do or have done with a multimeter to figure it out would be awesome!
Here is a picture of the trim. It isn't my pic but this is it. Got it off the web.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Ppoggio
  • 1,497
  • 29
The easiest test to perform, as Ben pointed out is to use a multimeter to measure the voltage to ground. In case you're not familiar with automotive electric systems, most metal on a car is grounded, but even that can be tricky because sometimes the metal is attached to plastic or painted, especially in the interior. I would recommend using the outer edge of your lighter plug. That usually works.
If the voltage is 12V, or close to it the trim is electrified to the car electrical system. Since you say it happens when the door is open, or when the vehicle is running, then my guess would be the trim has been shorted to some interior lighting circuit, possibly some accent lighting underneath or near the trim bar.
Paul Dufresne
  • 818
