I drive an old mechanical (non fluel injection) gasoline manual transmission car, and my approach to braking is pretty much as follows:
  1. Cruising
  2. Dissengage acceleratior, press clutch 100% in
  3. Press break pedal accordingly
And now things change depending on if the reason I was breaking still exists (for example, the light change or the car in front accelerates)
In case I need to fully stop I:
  1. Continue tu break till I come to a stop
  2. Shift to neutral, disengage clutch
If I need to resume:
  1. Down-Shift in to gear according to my speed
  2. Rev-match and accelerate, carry on
I've been told many times this is not the correct way to do things because a car coasting in neutral or breaking in neutral isn't a car 100% under control.
Can anybody please elaborate and state the proper way of doing this?
Cullub
  • 1,364
  • 14
  • 37
EChan42
  • 1,005
  • 23
The correct procedure for braking in a manual transmission car is as follows
  1. Driving as normal
  2. Apply brakes with a gradual increase in pressure
  3. Before the car stalls depress the clutch pedal
  4. Slightly release pressure before a complete stop to ensure a smooth stop
When stationary for longer periods shift to neutral and release the clutch.
Each car is slightly different so you will need to learn with your own car what point to press the clutch in for step 3.
Mauro
  • 2,665
  • 16
  • 24
