I am planning to replace my front brake pads within a month. I was told that if my brake wear sensor trips, I will need to buy new sensors as they will get destroyed. So I am trying to save my brake wear sensors by replacing the front brake pads before the sensor actually trips. For that, I am looking for a very rough estimate on how many kilometers I can do before my front brakes wear out by 1mm (this is how much is left before sensor tripping). This is considering mix of city/highway non-aggressive, slow braker style driving.
The car make is a 14 ' Audi S4 (B8.5).
eYe
  • 821
  • 20
Here's a rough approach that should work regardless of vehicle
You will need to know
  • the current brake pad thickness
  • the thickness of a brand new brake pad
  • how much mileage you've put on the car since the last brake pad change.
The formula
Mileage per mm = mileage since last brake change
               / ( brand new thickness - present thickness )
In essence, this formula assumes a linear wear rate.
Example
New E39 M5 brake pad thickness = 10 mm
Old E39 M5 brake pad thickness = 2 mm
Mileage accrued                = 25,000 km
Mileage per mm = 25,000 km / ( 10 -2 ) mm
               = 3,125 km per mm
So I can now anticipate roughly when the next brake pad replacement is due before the brake wear sensor trips.
E39 M5 Brake Pads - new vs old
Zaid
  • 39,276
  • 50
  • 151
  • 294
From what I can see, if you opt for the Pagid, Bosch, Brembo or ATE front pads for this vehicle, the wear sensor is included in the box. It is also available separately with a UK retail price of the equivalent of less than 20 USD.
Have you checked with the supplier of your new pads to establish if the sensor is included or not? Wear sensors are sacrificial components that are both cheap and easy to replace.
As for how long your pads will last before you trip the sensor, this is impossible to gauge. You may, driving gently and allowing the car to coast, get several months use. You may however find that a single piece of evasive action taken at highway speeds is enough to trip your sensor. The S4 is a fiercely quick car and relatively heavy too so it would be possible to burn up a brand new set of pads in a single afternoons track use.
Steve Matthews
  • 23,464
  • 41
  • 92
