I have a 2005 PT Cruiser Convertible that's leaking oil in #4 cylinder causing engine light to come on. Now, I have changed valve cover gasket and tube seals, spark plugs and wires and coil, pcv checked okay, compression test on all cylinder was 120.
Still leaks in #4 and light comes on with code 304. Any suggestions?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Doug
  • 31
From obd-codes.com:
A P0304 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #4.
A code P0304 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Running out of fuel
  • Poor compression
  • Defective computer
I would recommend checking compression on your 4th cylinder. If it's really bad, it not impossible a bit of oil is seeping in there. It could be time for a piston ring replacement.
anonymous2
  • 5,255
  • 30
  • 59
