I have a 2003 Buick Century and whenever it is dark out my car turns my lights on automatically upon turning the car on, the right blinker stays solid. This has been going on for a while but now when I signal to turn my left dashboard lights up and my entire car dies. Also, my left turn signal now blinks incredibly fast so I replaced the bulb today and it's doing the same thing and I just put a new battery in my car two days ago. I'm going to replace the combination flasher relay but I'm not sure if that is the solution.
I replaced the combination flasher relay today and I'm still having the same problem
Sounds very like an earthing problem. Check the earth on your lights, lh side obviously is doing something funny to the ECU.
Often trailers do these odd light swapping games if earth is uncertain.
Bevan
  • 561
  • 17
Sounds like light sensor grounded out when it turns lights on sending electric to CPU on a ground or your to your dash board .I'd say it's grounded to your turn singnal wire?when two hots trying go through CPU automatic shut down. Try in hooking sensor that turns lights on .most vehicle you can mash emergency pedal down one noch or pull brake up one turn lights off.hope you have luck finding it .them light sensor do go bad like that or it's got warm I'd say kinda melted into a wire .
I have a Malibu 03 with similar tail light problems check for moisture in the tail light assembly and replace entire assembly as the contacts corrode and cause all sorts of problems! Once replaced if there was moisture then check fuse holder for heat damage as sometimes a person will put to large a fuse in to compensate for frequently blown fuses!
Typical of a faulty ignition switch. The contacts internal to the he switch get worn over time. The extra load of lights and the blower motor just exaggerated the problem. Check the voltage at the engine control module fuse or fuses with the lights on. Also check the voltage at all fuses when the car has stalled out
