I have a 2013 Chevy Cruise that has new brakes changed by the dealership, and they work perfectly in the rain, and dry conditions. But when there's snow on the ground, the brakes often start grinding, and I can feel it in the pedal (I can also hear it). This happens at the end of the stop. I assume it has something to do with the ABS mechanism in the car.
Why only when it's snowy?
What is happening when this occurs?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Mena Labib
  • 179
Normal Sounds
The sound you are hearing is the ABS releasing pressure within the system to allow the wheels to continue to rotate and not lock up when you apply the brakes in low friction conditions.
As the snow builds up and you encounter low friction driving conditions due to snow and ice the ABS will kick in more frequently because you are encountering low friction conditions.
The 'grinding' you hear and feel in your peddle is by design. You have nothing to worry about.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
