My motorcycle, a KTM Duke 200, while riding is producing varying acceleration. This is during a single ride. For about a few minutes, the acceleration is alright, then after a few minutes, the acceleration seems to drop. Once I turn off the bike at traffic, and I start again, the acceleration seems normal. After a few minutes, the problem occurs again.
  1. The fuel is not a problem, as I'm refilling high grade fuel, which I've been using from a long time.
  2. I've checked out the air filter and I clean it thoroughly. In fact, even changed it to just check if that was the issue.
So what might be a problem? Am I looking at anything major?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Iceman
  • 181
Since this is a fuel-injected bike, this sounds like an air-fuel mixture problem.
Air-fuel mixture problems arise when the mixture is either too lean or too rich. If bad enough, both can result in poor acceleration:
  • In lean mixtures, there is too much air and/or too little fuel
    Typical causes for this include an intake leak which is allowing unmetered air, malfunctioning MAF/MAP/lambda sensor and partially-clogged injector.
  • In rich mixtures, there is too little air and/or too much fuel
    A stuck-open injector, over-pressurized fuel line, under-reading MAF/lambda sensor could cause this.
The temporary "restart" fix makes me suspect a bad lambda sensor; it's quite common for vehicles to run in open-loop mode for a couple of minutes. Assuming this is a narrowband sensor, you could confirm that it is working as it should using the test outlined here.
Zaid
  • 39,276
  • 50
  • 151
  • 294
It may be something with the ignition system. Check the spark-plugs. This tends to happen if there is dirt or some type of gunk on a spark plug.
Might be worth checking the throttle position sensor.
The fuel system may require cleaning with some Seafoam or some liquid cleaner that works well with cleaning fuel systems.
mr_tuner
  • 440
