I first purchased my Civic in Jan of 2015. My first car had terrible over heating problems so I decided to get rid of it for my civic. Turns out, my Civic has the SAME problem. I decided to take it down to Daytona for a road trip when I bought it and halfway there I saw it was all the way on the H. I stopped at a rest stop (thankfully) and this really nice guy put water in it and told me I had absolutely no coolant. I thought, okay that's fine, I'm an idiot for not checking, it should be fixed. Well, when I got to Daytona I took it to my Uncles house (he's been a mechanic for years) and after a little research we decided that I needed to replace my thermostat and my radiator. we also took out my condenser. but low and behold, that has not fixed the problem. I've had diagnostics run on a lot of things and everything has come back working just fine.
WHAT ELSE COULD BE THE PROBLEM!?
I put coolant/water in it every single day before I drive it and it's been fine for a while, and there are no leaks, my oil is not milky, and my exhaust is fine. PLEASE HELP! I want to keep my car, thank you!
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Taylor
  • 41
If you are loosing coolant, it has to be going somewhere. You are either leaking it or burning it.
You can get a radiator test kit to help determine where the leak is. Basically you put a small pump on your radiator, add some air to increase the pressure to about 15 psi, and look/listen for leaks. Listen in the valve cover and cylinder hole to determine if it is a head gasket.
Otherwise, you can start your car and let it heat up. While it is nice and hot with good pressure in the system, look for a leak. Since you say you do not see a leak, pay special attention to coolant hoses on the back of the engine. There should be some coolant lines going to the intake somewhere. Be sure to look closely at those and any gaskets. Leaks on the back of the engine may not be obvious if you aren't looking right at them. You may need a mirror to see everything. It is also possible is it leaking at your water pump. I believe this is connected to your timing belt, so this may be difficult to see. Certainly look around the timing belt area and crank pulley for wetness.
The easiest way to check your head gasket is to do a compression test each cylinder should be within 10% of the others and at least 120psi. This will not test if you have a break between coolant and oil, but since you do not have milky oil, it is unlikely it has blown in this way.
rpmerf
  • 8,458
  • 22
  • 31
