I have a 2008 Toyota tundra that I replaced 1 headlight on thinking it was bad but then replaced it a second time and it worked fine for 1 day and the all of a sudden now I do not have any low beams on either side. I have high beams. I was told that maybe a fuse or a relay.
What are the chances that it is just a fuse?
Could it be anything else?
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
nanar
  • 81
While your're checking fuses, don't overlook the connector(s) on the headlights themselves. Sometimes they fail over time and other times due to people putting higher wattage bulbs than the connectors can handle.
Most modern headlight bulbs have two filaments in the same glass enclosure: one for low beams, one for high beams. I imagine that you use low beams most of the time, so the corresponding filament burned out sooner.
If you have this problem only with one headlight, I believe this is the reason. If you have this issue with both, I'd start with the fuses and relays.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Olaf
  • 121
