I rent in an urban area, so I don't own a shovel - weather almost never requires! But the East Coast got hit with an unusual storm, and my car is snowed in.
Is there a way to dig out my car without damaging it short of buying a shovel, to be used only once?
Ideas that come to mind: rent a shovel, using some kind of sharing network, ask a neighbor, pour hot water. I have called a few hardware stores (none rent) , can't find any share economy sites for this, and CL didn't have anything listed. Suggestions? Other info: hard snow, heavy, about a foot deep, ambient temp is ~ 40 F. Thanks!
anonymous2
  • 5,255
  • 30
  • 59
anon01
  • 205
  • Door Mat Scoop - Depending on how compacted the snow is that surrounds your car, you may be able to get away with using a doormat as an improvised snow scoop. This would be a good option (assuming you have one), especially if the snow has not long fallen.
  • Car Towing - If you have access to another car (preferably four/all wheel drive), and you can access the car tow point you could use a tow rope to be able to apply a force to the car stuck in snow. Hopefully, this force will be enough to pull the car free before the wheels on the towing vehicle lose traction.
  • Hand Winch - Along similar lines as the towing situation, but without the need for another car, you can consider using a hand winch. You need a secure anchor point and again the ability to access a secure towing point on the car that is stuck. There is a good post about these here.
However, if I am correct in assuming that none of the above are a viable option for you due to your urban, and hence somewhat unprepared situation - you may also find some of these tips useful. I think that many of the tips I gave about how to get your car out of a snow bank would also apply to your situation because a lot of the points that were made there assumed that you had access to limited tools (though some didn't).
Max Goodridge
  • 7,957
  • 19
  • 53
  • 105
