What is the steering ratio for the European Ford Focus Mk2 that was in production between 2004-2010? I can not find it anywhere... I need it for a research project. There is somewhat relevant answer about C-Max steering ratio but that is on a different & newer model so I suspect the Focus may have a different ratio.
Thanks for help in advance!
EDIT 1: I found an article with a 2013 Focus steering ratio and it says 14.7:1 which is the same like the above linked 2013 C-Max... however 2013 Focus is a European Mk3 and I need Mk2.
EDIT 2: A sweedespeed forum post mentions 13.2:1 for a 2009 Ford Focus RS. In case the steering was not modified for the RS version (the post notes 14.7:1 for Focus ST which most likely is a Mk3 and equals to the 2013 values above) then it may also be valid for basic-level Focus Mk2.
