I have 2 questions actually. But I feel there might be connection so I decided to combine this 2 queries.
First: During slow start drive I hear this low screeching sound like something is loose. I'm trying to figure out where it is coming from but it is hard since the sound is produced only while the vehicle is moving. I know I need to check and tighten bolts somewhere but if someone can provide me the major points to check so that I can little by little check which caused the screeching. My car is Mazda 323F 2000 Model AT.
Second: I recently brought this up to a couple of mechanic already. This happens when I slightly press the break pedal during slow drive on traffic moving to a stop (or if the vehicle is slow moving). The break would screech loud. I checked the break pads and it is still thick and I see no damage on the disk and drums as well. The mechanic also said that this is normal for automatic vehicle? I think otherwise. If anyone can give me suggestion on how to avoid this loud screeching sound that would be great. Also is there a possibility that this and my first question is somehow related?
I know this might be too broad but maybe you gurus can help me try something to narrow the possibilities down.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
L42
  • 441
  • 18
This definitely sounds like some brake pads are worn down to the indicator wear bar. It is supposed to make a screeching noise when this happens. Don't take the car back to the mechanic who said this was normal for an automatic! But do take it to a reputable shop for another opinion. And yes, both points of your question are probably due to the same condition.
Rotten Ronnie
  • 348
Do you know if it's coming from the front or rear? Also double check your serpentine or v-belts... They may be loose or just need some belt dressing. I know they can sound like that when at idle or when stopping.
Dee
  • 697
  • 14
