I found out recently that the flywheel, driven by the crankshaft, is connected to (or part of) the clutch. I have a basic understanding of what a clutch does due to the fact that I know how to drive a car. By this, I mean that I know the clutch is disengaged when I put my foot on the pedal and that this results in the engine not being able to pull the car forward (as the power from the engine can not get to the wheels) - but I have no idea how this works.
I have a few questions about this:
  • What is a clutch?
  • What is the effect of pressing the clutch pedal down?
  • What is a "clutch plate" and how is it related to the clutch?
  • How do these things relate to the flywheel?
Max Goodridge
  • 7,957
  • 19
  • 53
  • 105
In general, a clutch is a part which allows to connect / disconnect two shafts also while they are rotating.
The most simple clutch consists of two discs, each firmly attached to one shaft. Press them together, and the friction between them allows to transfer torque from the one shaft to the other. Pull them apart, and the shafts aren't connected any more, and each shaft can rotate at its own RPM.
The important point is that the clutch discs can slip until both shafts have the same RPM. This makes them different from gear wheels, which can also connect/disconnect shafts, but already needs the shafts to have the right RPM ratio.
A typical clutch in a car is not much more that that two disks:
The orange clutch plate is connected to the shaft to the gear box, the blue is the flywheel, connected to the crank shaft.
Normally, the yellow pressure plate is pressed (due to the diaphragm spring) to the clutch plate, and also presses this to the fly wheel. Motor and transmission are connected.
If you press the clutch pedal, the inner part of the spring is pushed left, which causes the outer part to move to the right. This also moves the pressure plate to the left, releasing the clutch plate. The motor is not connected to the transmission.
It is not necessary that the left disc actually is the flywheel, but as the flywheel already has about the size needed, it is usually used as part of the clutch.
A few more words about the clutch in the car:
If you disengage a gear, you put lots of wear on the teeth of the gear wheels, when there's still torque applied to them. So the clutch removes this torque, and allows to disengage the gear gently.
If you engage the new gear, the shaft between gearbox and clutch still has not the right RPM matching the gear and the RPM of the shaft to the wheels. Therefore, each gear has some kind of "mini-clutch" called synchronisation ring, which brings that shaft to the right RPM (and correct position). But this clutch is only for that small shaft and is too small to bring the entire motor to the right RPM. Also, it is only used to match the RPM, not to transfer the torque while driving.
Just to mention other types of clutches:
Most scooters have this kind of clutch, which looks similar to a drum brake (but e.g. without piston)
The entire reddish part is connected to the motor side and rotates counter-clock wise. When the RPM is increases, the orange parts are pulled outwards due to centrifugal force and so are pressed against the green drum, which is connected to the wheel. The only reason for that clutch is to disconnect wheel and motor while idling.
Bob Cross
  • 24,537
  • 85
  • 166
sweber
  • 7,067
  • 24
  • 43
A clutch works in exactly the same way as your brakes. The flywheel is just a big metal disk at the end of the crankshaft. Your clutch plate is a round piece of friction material (just like a brake disk) that is pressed hard onto the flywheel so it can transfer the power from the engine to the transmission (and from there to to wheels).
When you press the clutch pedal you pull the clutch away from the surface of the flywheel.
When you release it, it gets pressed up against the flywheel. When it's pressed onto the flywheel, it causes the driveshaft to turn the transmission.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Captain Kenpachi
  • 8,888
  • 26
  • 43
To add a bit to Sweber's post. There are also multi-plate clutches that are you used in most motorcycles and very frequently in automobile racing like IRL and F1.
A good video on multi-plate clutches.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
