I had someone come look at my car (big mistake I should have done I it myself). He said the spark plugs needed to be changed and while he was changing them he was revving the engine. He didn't put the spark plugs back correctly. I got the spark plugs in order but now my car will not start. It has power but does not turn over.
What could be the problem?
George
  • 6,605
  • 38
  • 86
  • 123
Selina
  • 51
It sounds like you need to charge your battery then the car will turn over and you can troubleshoot why it's not starting.
You can either
  • jump start the car from another car using some jumper cables
OR
  • you can put the car on a battery charger to get the battery charged
Once you get it turning over, you can try and figure out the 'will not start' issue.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
