10
2007 Chevy Avalanche 5.3 vin 3.
I bought a remanufactured engine. After installing it, the truck runs, but only bank 1 (1,3,5,7) is firing.
It has power to the coil packs on bank 2 (2,4,6,8), but no spark. I put in a new cam sensor, crank sensor, and all 4 O2 sensors, but bank 2 will still not fire.
  • What could be causing this?
  • How do I diagnose it?
anonymous2
  • 5,255
  • 30
  • 59
Shaine
  • 101
This post is old but today I was called out to a truck with the same problem. It turned out that one of the coils had shorted out and blew the fuse for the left bank. I replaced the coil and replaced the fuse and all the cylinders were firing again. The fuse was a 15 amp under the hood and labeled *2 with a note to check the manual as to it's purpose. Next to it was another labeled *1 and I would guess that to be the other bank. Hope this helps.
Dan
  • 31
Check the battery, maybe some cables which should be connected to the sparkplugs aren't. Check the alternator, maybe it is not restoring enough power for both banks. A friend of mine had the same problem. He checked the sparkplugs and one bank had no power, because of loose cables. But please do not try to drive! Your issue could badly affect the crankshaft and the conrods of the second bank.
MightyV8Engine
  • 399
The last one I did the #2 side was firing when first started then after about 30 to 45 seconds the whole side would miss . I found corrosion in the under hood fuse block around the #1 and #2 fuse connection sprayed Kroil penetrating lube in those fuse ports and it is corrected the problem?
