I am not well versed in diesel engines. To prove my point, I've learned in the last month that a two-stroke diesel engine actually exists.
My Question.
What kind of diesel engine (four-stroke or two-stroke) is most commonly used in heavy vehicles that we all see roaming about the surface of the planet?
AND
What is the reason a two-stroke or four-stroke engine would be the most used in a particular application?
I would imagine that a two-stroke diesel engine would have a higher emissions footprint, regarding hydrocarbons, than a four-stroke diesel engine due to the way that two-strokes function but this is an assumption on my part.
DucatiKiller
  • 32,976
  • 22
  • 150
  • 267
Most small(ish) diesel engines in cars, diggers, generators etc are 4-stroke.
The main reason being efficiency - Although a 2-stroke engine is technically capable of more power output, a 4-stroke engine uses less fuel to produce the same power output.
Many VERY large diesel engines (EG Super-Tankers) are 2-stroke, This is because they are direct drive (propeller shaft attached directly to the crank with no gearing or clutch) these are classed a Low speed engines, and can burn much cheaper Heavy Fuel Oil.
